Problems connecting Archos Gen 5 dvr station to a tv with built in freeview
Discussion in 'Video Streaming Boxes & Services' started by Alex_Wales, Feb 11, 2009.
  1. Alex_Wales
    Alex_Wales
    I have an archos 605 wifi and a generation 5 dvr docking station. I can connect and use this correctly with through a virgin media box and a tv but am struggling to connect it correctly with a tv that has built in freeview. If anyone knows how to do this correctly i would be very grateful if they could explain this to me?
  2. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    If you are trying to record from the Freeview receive in the TV then check which of the TV outputs can carry the Freeview material as sometimes it is only available on one SCART for example.
  3. Alex_Wales
    Alex_Wales
    thanks very much, is there a way to find out which scart can carry the freeview? is it just trial and error? will one of the two scarts definately caarry the freeview? thanks again
