Problems coiling speaker cables?
Discussion in 'Cables & Switches' started by Ambienz, Sep 24, 2005.
  1. Ambienz
    Ambienz
    I have a large room (about 50ft x 25ft) in which I have some B&W ceiling speakers for background noise, and some proper speakers in the 2 corner when I want to listen to music.
    The amps etc are set up quite a distant away from the 2 corners where the main speakers are - one obviously a lot closer than the other.
    Now given the size, in order to maintain equal lengths of speaker cable from amp to speakers one of the speakers has quite a lot of excess cable.
    Is it OK to coil this cable around in order to hide it away?
    Remembering back to my physics days one shouldn't do this with 240v electric cable due to the forces exerted relative to the flow of the current. Is there any similar result or interference if one coils speaker wire when in use?
    any thougths or feedback greatly appreciated.
    David.
  2. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,937
    Manchester, England
    +81
    tbh I have never read anything to convince me that different lengths of cable really make an audible difference to the sound. Just make them the length they need to be and see how you get on.
  3. Slimchandi
    Slimchandi
    Dec 23, 2004
    467
    +3
    I would suggest that coiling is a bad idea. Coiling will create a magnetic field inside the coil, which would affect the signals being carried in a negative way. If you have to, wind them backwards and forwards (like a concertina, do you see?), and the cumulative magnetic effect should be reduced.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,789
    The Borders
    +2,467
    Hello Ambienz
    If you do keep the cables the same length its usual practice to 'coil' the cable in a figure of eight pattern - I think Slimchandi is suggesting the same thing :)
    Best regards
    Joe
  5. Slimchandi
    Slimchandi
    Dec 23, 2004
    467
    +3
    As long as you avoid placing cable on top of itself with the current going in the same direction.
    The magnetic field from a wire is circular around the wire (picture an archery board, the wire runs through the middle, the field lines are the circles surrounding it. Now if you loop this wire around into a circle, inside that circle the two fields from each loop will point in the same direction, giving a cumulative effect. If, instead, you wrap the wire so the currents are travelling in the opposite direction, such as a figure these fields will cancel to some extent. What you do not want is lots of coils as these small fields soon add up, and the low voltage signals in speaker wire will be adversly affected.
  6. Docta teef
    Docta teef
    Nov 21, 2003
    1,257
    Manchester
    +56
    Cable/wires should never be coiled except in an electric fire
  7. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Cut them down to length, or at least tell me a good reason not to. :)
  8. Slimchandi
    Slimchandi
    Dec 23, 2004
    467
    +3
    So when there's an electric fire, I can coil my speaker cable then?
  9. Docta teef
    Docta teef
    Nov 21, 2003
    1,257
    Manchester
    +56
  10. Docta teef
    Docta teef
    Nov 21, 2003
    1,257
    Manchester
    +56
  11. baldrick
    baldrick
    Dec 28, 2002
    3,365
    Providence, Rhode Island
    +247
    I tend to 'double back' excess cable so you end up with what is effectivley an 'S' shape.
    'Coiling' in a figure of 8 is the proper (neat) way to use up excess cable alternatively just 'spaghetti' it!!!
  12. DeeeKaaY
    DeeeKaaY
    When running (very large) speaker cables at concerts I was always told to coil the excess (health/safety & tidy). We _always_ coiled one loop each way, alternately (referred to as french coiling at my work). Except where the excess was very long (like at sports matches) when we used figure of eight coiling.
    When packing for a gig we would plan for the amps at one side of the stage; all the speaker cables on one side were short (3m) and all the speaker cables for the other side were long (25-35m).
    Personally I buy extra cable, french coil the excess and hide it out of site.
    dk
  13. stebbo
    stebbo
    Nov 28, 2003
    174
    16
    Basingstoke Hanmpshire
    If you refer to "Kirchoffs Law" in your Physics text books you will realise that coiling a cable that transmits AC signals is of no issue.
    Secondly. There will be no difference in speaker cable length as long as you are not talking differences in excess of many metres.
  14. Will Scarlet
    Will Scarlet
    Oct 1, 2005
    2,105
    2
    Eastcote
    +250
    I must say that I find the coiling theory a little strange. I have no argument regards the idea that a single wire/conductor when coiled will have an increased inductance. But speaker cable consists of two wires/conductors, one negative, one positive, both of which conduct current. These currents run in opposite directions, and as a result you get two induced fields which should, in theory, simply cancel each other out.
    As I pointed out in a previous post, I read of an experiment that was carried out where a length of speaker cable was coiled tightly around a 2" diameter steel bar with no appreciable effect on the its performance. Unfortunately I can't remember the link to this web page but if I find it again I'll post it for you to study the findings. I am no expert, but given the above, I find it hard to believe that loosely coiling excess speaker cable will have any noticable effect on the average persons system. More speaker cable snake-oil methinks, akin to the speaker cables of equal length theory, which unless you are wiring the Albert Hall seems rather dubious too.
    I stand to be corrected of course, but for now I'll coil.
  15. stebbo
    stebbo
    Nov 28, 2003
    174
    16
    Did I not refer you to Mr Kirchoff? :)
    Do it my good man, it wont make any difference.
    Enjoy the music in the knowledge that nothing untoward is going on.
