Problem
Discussion in 'AV Receivers & Amplifiers' started by Andywilliams, Oct 3, 2003.
  1. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    Hi folks
    Right my problem is i have to have my tv in the right corner of my room.I can only store so much equipment under my tv.On the left side of my lounge(16'side) ive got a gap between a dresser and a sofa of about 2' this gap is about 9' away from my tv.How would i connect everything up if i brought a rack this far from my screen and speakers (extra long coax from dvd player under tv also cd player under tv.)The reason i ask this is that i need to get a beefy amp to drive my m&ks also would like some feed back on amplification budget around 2k.Room size 16'x14'.
    Thanks in advance Gonzo.:)
    Ps I cant fit a bigger av stand where the tv is.
