problem with US version phillips 963SA
Discussion in 'Blu-ray & DVD Players & Recorders' started by zoro, Jan 23, 2003.
  1. zoro
    zoro
    Jan 23, 2003
    326
    +7
    urgent!
    I used the firmware, listed on ur site for r2 players, by accident on my r1 player, without realizing it was pal prog out the box!
    Now, i am screwed up. it plays only pal discs, and i cant even access menues on rca/s video/component video connections...
    In prog mode, there are twigly green lines, no welcome page, and I cant access, system menue for reset!and I cant play ntsc discs, says error! darn it, I am screwed up., pls help me to undo this unnecessary damage!I can be accessed on icq too!
    Ps. orig firmware was posted by John archer!If he can rescue me..pls?
    http://www.homecinemachoice.com/news/index.html
    link to john archer's firmware post!
  2. ebury
    ebury
    Nov 5, 2002
    1,268
    41
    london
    +12
    dont think my problem is the same as yours but i also am getting the green lines you mention.my player is r2 hacked for multi/PAL using the well known codes.all functions are working fine except on the component output!maybe there is a universal problem with these green lines?have you checked for any info on avsforum?any news?
  3. zoro
    zoro
    Jan 23, 2003
    326
    +7
    i had US player working fine, on pal prog/ntsc prog with component video till I screwed up putting..john archer frmware..unnecessarily, now dont know? how to revert back?
  4. Timh
    Timh
    Sep 14, 2000
    5,149
    2
    3
    Altair-4
    +279
    Try contacting philips they should be able to provide you with the original firmware, maybe by downloading it from the net.
  5. soundman38
    soundman38
    Oct 31, 2002
    Zoro
    Check the back of your machine and input the appropriate factory code.
    DVD963SA/001 play 159 222 012 00 play
    DVD963SA/171 play 159 111 010 00 play
    DVD963SA/691 play 159 323 010 00 play
    This should revert your player to out of the box settings.
    Please tell me you findings.
    Greetz soundman
