Problem with Toshiba SD330E
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dave Bartram, May 23, 2004.
  1. Dave Bartram
    Dave Bartram
    Nov 23, 2001
    1,015
    48
    Essex
    +61
    Hi, bought a Toshiba SD330E yesteday & I'm either having problems setting it it up or it's faulty. Plugged it in using component video leads & the picture scrolls/rolls when the film is being played. It does this for say 1/2 a second then you get a proper picture for a second or so then is rolls again, it is fairly inconsistant though. It works fine when using the on screen set up & also on "some" static screens i.e the menu screen on Austin Powers. It's a Multi region player & I've tried both R1 & R2 disks & also tried connecting via S-Video, composite & Scart as well.
    If it helps the TV is a 42" Plasma Hyundai which I also connect a Philips DVD recorder without any problems.
    Dave
  2. Dave Bartram
    Dave Bartram
    Nov 23, 2001
    1,015
    48
    Essex
    +61
    Small update, some software works & some dosen't....
    Either rolling or maybe 2 images on screen a few pixels apart so looks fuzzy are:
    Austin Powers R2
    Dragon R2
    Hard Rain R1
    Seems to work fine are:
    Bugs Life R2
    Collateral Damage R2
    Bill & Teds Bogus Journey R2
    Any thoughts before I speak to supplier/Toshiba?
