Problem with TomTom 510
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by SheDevil, Aug 28, 2006.
  1. SheDevil
    SheDevil
    Mmmm, well after just buying my hubby the tomtom 510 a week ago , we r already having a problem ! it seems to be frozen .... won`t turn off ...won`t do anything when we touch the screen, have tried running the battery down ,, tried charging it up, removed the card .... Anyone any ideas .... if this can be fixed .... or should we contact the manufacturer, I bought from Amazon, so will have to have a look at the returns procedure, in case ... but hoping its just a temporary glitch.
    :devil:
  2. dayna62
    dayna62
    Apr 29, 2005
    69
    +3
    reset the unit by turning it upside down, and sticking a paper clip in the "re set hole" check your user manual if you are unsure
  3. RekalinSimms
    RekalinSimms
    The hard reset should do the trick. If it doesn't, let us know. The 510 is a pretty nice gadget, so hopefully this will fix the problem.
  4. supremedevil
    supremedevil
    Aug 28, 2006
    2
    Thank you for this advice i had the same problem and now it works fine :thumbsup: thanks
  5. SheDevil
    SheDevil
    Thanks, we pressed the reset ... then plugged it into charge & everything is running again.
    :devil:
  6. steve_d
    steve_d
    I heard that TomTom are thinking of including a free paperclip with all their X10 models. It's the most used accessory apparently. :rolleyes:
  7. dayna62
    dayna62
    Apr 29, 2005
    69
    +3
    If anyone would like one of these "specialist tools", i can provide them for free. Postage however is £9.99 to anywhere in the world:smashin:
  8. RekalinSimms
    RekalinSimms
    Just glad to know it all worked out for you/ Make sure your firmware is the most up to date as well b/c the most recent one was supposed to help out the 510.
  9. atoche
    atoche
    IMHO - you should not load new firmware ASAP when it comes out. I would advise waiting at least 2 - 3 weeks, and let the early adopters figure out if the firmware is good.
    If you watch the TomTom Home site, they will post an update - then take it down after 2 days (due to newly discovered bugs in the release).
    Err on the side of caution!
  10. gilbertcross
    gilbertcross
    I had that problem, too, and the paperclip reset trick fixed it. Also, mine has had some issues when it gets really really cold (sub zero)...but it's fine once it gets back up over 0.
  11. ek_1986
    ek_1986
    Mar 25, 2007
    4
    Im having some problems with my TomTom 510 as it will not turn on and when i put it through on charge the Green light appears on which must mean that it is charging up. I am not sure where exactly the reset button is on the TomTom 510 and was wondering if someone could Plz help me!! :confused:
  12. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,052
    +7,223
    See thumbnail.
  13. pgendreau
    pgendreau
    Thanks, I've been racking my brain looking for the reset !!
    THANKS a ton !!
    PG
  14. SheDevil
    SheDevil
    Well, long time since my original post regarding this Tomtom, we have had over a year, with everything running smoothly, now we are at deadlock, please can anyone help, first of all we have tried, the paper clip thingy. LOL no help this time Im afraid, it will not switch on, will not reset, will not charge up, when we try to reset, the screen lights up for a second then goes off, thats as far as we can get ... the year warranty is now up, as we bought last august.
    What can we do now ???
  15. Markywuk
    Markywuk
    Jun 3, 2005
    13
    3
    Exactly the same thing has happened with ours just yesterday - reset will not work - green light shows there is power going through but unit will just not switch on - & just outside 12 month warranty - will give it a go though - although any other ideas most welcome.
    Mark
  16. suman_das
    suman_das
    Dec 17, 2005
    17
    Ring up TomTom Customer support to check, my TomTom One v2 comes with 2 years TomTom warranty. (I understand the latest v3 has only one year though, less reliable may be?)
  17. SheDevil
    SheDevil
    Thankyou, just to let you know where we`re at ... we contacted Tomtom, who sent us out a box freepost, to send the tomtom back to them, & they are going to repair it free of charge, not sure how long this will all take, but thats the news so far, will let you know how we get on.
  18. ianhayman
    ianhayman
    Hello,
    I had exactly the same symptoms when I connected my tomtom 510 to my PC and then disconnected it without disconnecting it via the software first.
    The solution for me was to connect to my PC and then disconnect using the PC software before manually disconnecting.
    I had to do a couple of resets along the way, as the device seems quite tempramental about what order you do things.
    :thumbsup:
  19. tommouk
    tommouk
    Jul 5, 2004
    290
    28
    Fleet, Hants
    +57
    Thanks for the tip. Had a similar problem with my TT one V3 today. Did as you said and reset it twice and re-ran TT home application. Left it connected for about 5 minutes while I decided which hammer to fetch from the garage to inflict maximum destruction upon it when it suddenly burst in life. :thumbsup: and the screen displaying "Do you wish to connect to a computer?" was displayed. :confused: (EDIT my battery was flat so this might have been a factor)
