Problem with this channel message on sky premier
Discussion in 'Sky Digital TV Forum' started by jezellis, Apr 22, 2007.
  1. jezellis
    jezellis
    May 30, 2005
    32
    +6
    Since the movie channels got re-branded I have been suffering from some movie channels reporting technical problems with the satallite feed ( just like you get in a very heavy rain storm ). At first it was movies HD1 that whould suffer. Now it seems to be channel 301 and 302 ( movies permier and premier + 1 ). I seems to happen every other day.
    If I do nothing, it seems to fix itself the next day.
    A reboot always fix's it. Once going into the anytime stuff fixed it.
    I have now turned anytime off to see if that changes anything.
    Anyone else suffering from similar problems.
  2. thomasb
    thomasb
    Sep 30, 2005
    204
    stafford
    +8
    have same problem,only with sky premiere and sky premiere+1.as you sad have to reboot or fixes itself next day or so.
  3. hysys
    hysys
    Aug 4, 2005
    134
    same problem here, i had to reboot 3-4 times already....
  4. StuBFrost
    StuBFrost
    Dec 20, 2004
    1,679
    48
    Manchester
    +98
    Me too.
    If I go and look at the signal level, it shows input 2 as being off. If I wait a few seconds the level comes back very low but the 2 channels become available again. If I reboot the box, the input 2 level comes back at a high level as normal.
    I think it may be when Anytime has downloaded it happens.
    Stuart
