problem with table of figures in mac word 2011
Discussion in 'Apple Forum' started by aerodynamic18, Dec 6, 2011.
  1. aerodynamic18
    aerodynamic18
    Oct 26, 2008
    2,011
    116
    N.Ireland
    +1,396
    guys i have been using word for mac 2011 for a couple of months but hit a real issue. I have automatically made my table of contents and that works fine but i can't insert a table of figures. I have the figures numberd correctly but when i go to inset ->table of figure and then i say insert then it says do you want to update the entire field or cancel. If i hit cancel nothing happens. if i hit update contents then my table of contents gets replaced with the table of figures !!!! i need both! can anyone help?
  2. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    43,862
    11
    13
    167
    ::1/128
    +17,116
    Sounds like the position of the cursor where you want to insert your table of figures is inside the table of contents. You can't do that. Move it out of the toc and it will work properly.
