problem with sound
Discussion in 'Blu-ray & DVD Players & Recorders' started by kayzee, Sep 16, 2007.
  1. kayzee
    kayzee
    Feb 19, 2007
    1,087
    Essex
    +100
    i have an old samsung dvd player downstairs (DVD-E232) and recently the sound has been playing up. there seems to be an excessive amount of background noise, sometimes unbearable. no settings have ever been changed on it! its connected via rca.
    just wondering if anyone had any ideas or if theres a quick fix.
    or if its on its way out...
    thanks
  2. Dankeech
    Dankeech
    Feb 1, 2005
    3,637
    Stevenage, Herts
    +299
    First of all do you have to turn the volume up a lot on the TV etc to get any sound from the DVD, or is the hissing high volume anyway?. It may be the case that you have volume control on your DVD player set low (if it has onboard volume settings) and by turning the volume up you're amplifying both the low-volume audio and the low-volume hissing hence the issue.
    Let me know.
    Dan.
  3. kayzee
    kayzee
    Feb 19, 2007
    1,087
    Essex
    +100
    woah forgot about this thread. yeah that does sounds like something it could be tbh. i have to turn the sound up quite a lot more than normal. how can i find out if the player has its own settings? (strange that it would of suddenly changed itself though!?) anyway thanks
