Problem with Sony VPL S500 Projector ??
Discussion in 'Projectors, Screens & Video Processors' started by nickedick, Dec 8, 2004.
  1. nickedick
    nickedick
    Hi !
    I have a problem with my Sony VPL S500 Projector
    I got green vertical lines over the hole area...
    What can i do to fix this =???
  2. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,576
    Woking
    +231
    How are you connecting it to your source? How long have you noticed these lines?
  3. nickedick
    nickedick
    It´s connected with a S-Video Cable...
    I have also tried without the cable with no improvements...
    The lines becomes stronger when the projector has been in use for aprox... 3 hours...
  4. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,576
    Woking
    +231
    It's difficult to say, this is a fairly old model and it could be down to something as simple as age. have you knocked or dropped it at all? Maybe it's the prism alignment or a convergence problem. If it does it on all inputs ( S-Video, component, VGA and composite then I think it's time to ditch it and upgrade as to repair it would not be economically viable. Sorry!
  5. Retze
    Retze
    Hi, i ´ve got the same one, i just signed in at this forum here, just for you... :smoke:
    Do you have a tv near the beamer?
    I just ask, cause i had vertical lines, too.
    They moved from top to the bottom.
    As i removed the tv-cable from the wall, the lines disappeared. :smashin:
    Vertical lines should be a cable problem anyway.
    Sorry for my bad english, my last school lesson is about 13 years ago.... :lesson: :thumbsdow
    If you have any further questions, write an email.
    By the way, the VPL - s 500 sometimes got some problems with overheating.
    Did you clean it from dusk? Did you try to change the color-temperature, when your problem occurs?
  6. nickedick
    nickedick
    Hello thank you for your answear....
    The tv is placed under the movie screen...
    The projector is placed far a way from the tv...
    What did you mean with color temperature in what meny can i find
    the setting for that ???
