Problem with Sony VCR - Tape stuck
Discussion in 'Digital TV & Video Players & Recorders' started by Matt, Jun 14, 2004.
Tags:
  1. Matt
    Matt
    Jul 13, 2000
    775
    Cambridge
    +19
    Have got problems with my girlfriends Sony SLV-SE820. There is a tape in the machine, which is making noises but it seems to have locked itself down. It just says eject on the display, pressing any buttons doesnt appear to do anything. If you get the menu up it dissapears after about 30 seconds.
    Is there a way to do a cold reset of the VCR? I suspect the tape might not be in correctly and guess that means a call to the repair man. I will be going round to hers tommorw night so any advice before then would be good.
