Problem with Sony HC-14 E used as a webcam
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by driesel, Jan 13, 2005.
  1. driesel
    driesel
    Hi folks,
    I have tried to properly use my Sony HC-14 E Handycam as a webcam but up till now I don't succeed in the task. After a while of proper operation with MSN Messenger e.g. it gives a blue screen and the camera shuts itself down. Is this a safety measure of the camera itself to maintain battery life or is this kind of a driver flaw or something else? Can anybody please help me because it doesn't seem the cam is broken or something (the images and vids are perfectly sharp and rich)? (I also get the cam turned out itself when running 'USB streaming' from Sony's 'Picture Package', it gives a blue screen then too - telling me 'no cam is found connected to the system')
    Cheers,
    DrIeSeL
  2. DigiStuff
    DigiStuff
    Jan 22, 2002
    151
    Take the tape out of the camcorder and then this should not happen..
  3. Brian110507
    Brian110507
    It is the correct operation of your camera - it is supposed to shut down automatically if the tape is not moving inside, as DigiStuff said leave the tape out but on some cameras you may also have to leave the tape door open.
