Problem with Sony 900V DVD
Discussion in 'Blu-ray & DVD Players & Recorders' started by Imran_UK, Feb 14, 2002.
  1. Imran_UK
    Imran_UK
    Jan 27, 2002
    1,232
    Nottingham
    +29
    Hi, I got my Sony 900 DVD this morning, it is multiregion and RCE compatible.
    I have a 21" Panasonic TV in my bedroom and I am using a fully wired scart lead.
    When I turn the DVD on I hear the clicks it makes, then the tv switches to the AV channel and then back to the channel it was on. When I press AV on the TV the picture is blank as if their was no DVD connected.
    When I press the display button on the Sony DVD remote the picture then comes on.
    I have got the output set to RGB on the DVD player. I have not had any problems with the DVD switching between AV1 and AV2 like other people so I don't think this is the same problem other people have been having.
    Many thanks to all that reply or help
    Imran_UK
  2. chrismoore
    chrismoore
    Mine's exactly the same. Is this normal
