problem with sky router connecting to PC
Discussion in 'Networking & NAS' started by Onkyo, Jan 6, 2012.
  1. Onkyo
    Onkyo
    Jan 1, 2009
    72
    Woking
    I have a sky router which has my samsung blu ray hard wired to it. I also have my xbox 360 connected via wifi and also a laptop connected via wifi.
    All these devices are able to pick up the router name correctly and have no issues.
    Now, my desktop in the bedroom is connected to the sky router via a pair of homeplug adaptors and here is where my issue begins.
    The PC is connected to the router but when i go to see the network name it simply says "network 3" and cannot see the sky router in the list of available networks yet it must be connected to the router as it has a internet connection.
    Can someone shed some light on what's gong on?
    Thanks guys
  2. maf1970
    maf1970
    May 2, 2006
    2,072
    Aberdeen
    +298
    Do you have any problem accessing the net from the PC connected via Homeplugs ?
  3. Onkyo
    Onkyo
    Jan 1, 2009
    72
    Woking
    no, connection is all good and no issues
  4. maf1970
    maf1970
    May 2, 2006
    2,072
    Aberdeen
    +298
    http://www.avforums.com/forums/networking-nas/731564-homeplug-faq.html
    Homeplugs allow you to extend your network by utilising the mains wiring in your house. When plugged in the homeplugs establish a connection to each other and create a network. This is transparent and we don't see it but it is there none the less. You then connect your PC at the other end and this allows you to connect to the router. If you use the software that goes with your homeplugs you will find that 'network 3' is the homeplugs.
  5. Onkyo
    Onkyo
    Jan 1, 2009
    72
    Woking
    Thanks for the reply but why can't I see the router name, the pc is connected directly to the router via the homeplugs so shouldn't it see the router?
  6. maf1970
    maf1970
    May 2, 2006
    2,072
    Aberdeen
    +298
    The PC is not connected directly to the Router. It is connected to the router via the homeplugs network(transparent so you don't see it).
  7. Onkyo
    Onkyo
    Jan 1, 2009
    72
    Woking
    ah ok I get it
    So is there anyway round this?
    Ditch the homeplugs and get wireless adaptor on PC?
  8. mickevh
    mickevh
    Apr 30, 2007
    7,104
    West London
    +1,691
    What's the problem you are having..?
    In IP networks, client devices don't need to "pick up the router name" to "work." As long as the clients know the routers IP address (the "default gateway" address) then they should work just fine.
    Routers don't advertise their presence unless they are offering addition services such as uPNP DLNA etc. etc. and they are a different kind of magic (and not all routers offer them.)
  9. maf1970
    maf1970
    May 2, 2006
    2,072
    Aberdeen
    +298
    :facepalm: WHY would you want to get round this ?
    Your network is working fine as it is.
    To ditch the homeplugs in favour of wireless is a BACKWARD :suicide: step.
    From this thread,as far as I can tell, you don't have a problem. :thumbsup:
  10. beerhunter
    beerhunter
    Nov 9, 2005
    6,335
    Hampshire
    +740
    Simples. Your network actually consists of two physical networks: WiFi and Wired Ethernet.
    The devices that are connected to the router via WiFi are showing the router's WiFi Network's SSID. The WiFi network's SSID can be thought of as the WiFi Network's name - it is NOT the router's name. When devices are connected via Wired Ethernet, obviously they will not be showing the WiFi SSID because they are not using the WiFi network.
  11. Onkyo
    Onkyo
    Jan 1, 2009
    72
    Woking
    The reason i brought this up was because i was having issues getting my xbox or blu ray player to stream from my pc and i thought it maybe down to the SSID names not being the same. Will this make any differerce?
  12. mickevh
    mickevh
    Apr 30, 2007
    7,104
    West London
    +1,691
    If you have devices using different SSID's then they are participating in separate LAN's. If the router doesn't do "something" to allow the traffic from one SSID to reach the other, then yes, the devices won't talk to each other.
    Keep everything in the same SSID unless you've got good reason not to (for example you want to avail a separate "guest" SSID distinct from your "normal" SSID.)
    Bear in mind that wif-fi client devices can only participate in one SSID at a time (unless they have multiple wi-fi adapters, which of course most don't.)
  13. Onkyo
    Onkyo
    Jan 1, 2009
    72
    Woking
    Ok
    Can someone please explain how I get all the devices talking together using the powerline adaptors as I cannot get my PC to "see" the sky router in the lounge.
    Sorry for the silly question but I am new to this sort of thing :lease:
  14. maf1970
    maf1970
    May 2, 2006
    2,072
    Aberdeen
    +298
    mickevh kinda covered your question earlier. :smashin:When there did not appear to be a problem with your network I did wonder if this thread was leading up to something else. So IMHO your question is really about streaming and needing help sort out your system so you can stream movies from your PC to your XBox 360 / Blu-Ray Player.If so more info is required -
    1. Is the XBox 360 connected to the net ? If so how ?
    2. Make and model of blu-ray player and if it is connected to the net.
    3. How do you rip your DVD / Blu-ray movies to your PC ?
    4. Which Sky router do you have ?
    5. Make and model of homeplugs.
  15. beerhunter
    beerhunter
    Nov 9, 2005
    6,335
    Hampshire
    +740
    Plug one powerline adapter into a spare port on the router. Now connect any device that you wish to connect via powerline to a powerline adapter. All the devices thus connected will appear to be on your Ethernet network.
