Problem with Sky Movie Premier
Discussion in 'Sky Digital TV Forum' started by Orri, May 7, 2007.
  1. Orri
    Orri
    Hi I was wondering if any of you have experienced problems with Sky Movies Premier Channel.
    Way to often I get the "Technical fault" message and this goes on for hours, then for a few days everything is fine and then we go again.
    I have noticed that on the on screen message the number 14 is displayed.
    Does that mean anything?
    All help appricated,
    From sunny Iceland
    Orri
  2. mgiazzi
    mgiazzi
    Mar 6, 2005
    91
    11
    +6
    I also had the problem and all i did was to unplug the box from the mains and reboot. Everything fine now. Hope that helps.
  3. Orri
    Orri
    Thank you my man, I'll try this tonight. :smashin:
  4. mats1965
    mats1965
    Mar 17, 2006
    122
    cornwall
    hi,im also getting this, it is ok after a reboot but will happen again later.
  5. C225
    C225
    May 15, 2006
    6,290
    Linlithgow
    +785
    Only way to stop it is to disable anytime or to get a new box from sky otherwise it will need rebooted everyday.
  6. contraste
    contraste
    Sep 14, 2005
    1,554
    Marylebone, London W1
    +97
    Happened to me last night. I went into the services menu and looked at the signal strength, input 2 showed no signal. As I was looking at it, the signal came back and now Sky Movie Premiere was also back on.
  7. hysys
    hysys
    Aug 4, 2005
    134
    I had the same problem, i disable anytime and now it is fine.
  8. colham
    colham
    Mar 31, 2005
    331
    MK
    +19
    I also have this problem.
    To be honest, Premier has become a total waste of time.
  9. fizl
    fizl
    Apr 21, 2006
    2,164
    Not in London
    +460
    I have this problem every day now.
    I want to keep anytime on, but this is driving me mad!
    Shaz
  10. hysys
    hysys
    Aug 4, 2005
    134
    Did you contact Sky ? what did they say ?
  11. StuBFrost
    StuBFrost
    Dec 20, 2004
    1,679
    48
    Manchester
    +98
    I also had this problem. Turned off Anytime and it fixed it.
    Stuart
  12. fizl
    fizl
    Apr 21, 2006
    2,164
    Not in London
    +460
    Am waiting for a response from SKY.
    I have found that if you record something in your planner it works, just for some reason you can't watch it live?
    Shaz
  13. gd2
    gd2
    Only problem with is that the films are rubbish since the change!
  14. J Roadley
    J Roadley
    Oct 24, 2005
    662
    28
    Norwich
    +55
    Yep - what is the point of this channel? Just wait and the same film will pop on HD 1 or HD 2 :D
  15. fizl
    fizl
    Apr 21, 2006
    2,164
    Not in London
    +460
    Got a phone call back from SKY after I told them they had a software problem.
    They said - funnily - that it is a software problem and they are looking for a resolution :)
    Shaz
  16. Joeki
    Joeki
    Jul 22, 2003
    50
    Starside
    Turning off Anytime worked for me. Pity, because it sometimes had some good things on it. Clearly something is very wrong with the current software. Might be good to have someway of knowing when its safe to turn it on again.
  17. kryten22uk
    kryten22uk
    Feb 4, 2005
    441
    28
    +32
    Spoke to Sky just now. They said that the problem is with the Satellite itself not them. Their considering switching to another satellite/transponder frequency which they think might fix the problem. But until they do they wont know if it causes something else wrong. Hence better the devil you know, was the phrase. He said that the estimated fix time was 4 weeks, but we arent eligible for a reduction to subscription because of the loss!
