Problem with Sky Box
Discussion in 'Sky Digital TV Forum' started by steevs, Aug 25, 2006.
  1. steevs
    steevs
    Jan 3, 2003
    2,914
    68
    wxm
    +73
    Hi all
    Im having a problem with my box, I have a humax 2000 and sky+, I have connected them together by a pass through cable.
    When they are both connected I get the message no satellitte signal is being recieved on all the BBC channels, all the rest are fine.
    I have tried disconnecting the humax and running both cables to sky and all is fine, I only have the problem when using the pass through cable.
    I have checked the cable and all is well with it so I dont understand why it doesnt work.
    Any suggestions?
    Steve
  2. FRANTIC FRANC
    FRANTIC FRANC
    Aug 7, 2006
    1,375
    63
    +86
    You need to try a feed switch box instead as both boxes will be putting down the 22khz tone down the cable or switching the 18v on the LNB. You could try turning off the LNB power in the services menu too.
    Cheers, Franc
  3. steevs
    steevs
    Jan 3, 2003
    2,914
    68
    wxm
    +73
    Thanks Franc
    I'll give that a go in the morning.
    1st time I posted on here but I read quite often and have seen you really know your stuff.
    Thanks for helping.
    Steve
  4. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
    Make sure only one box is out-of-standby at any time. Make sure the box in standby is on a low-band vertical polarisation channel.
  5. lynx
    lynx
    Jan 20, 2002
    4,653
    It always rains.
    +302
    Moving to Sky forum...
