Question Problem with signal meter
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Skylinestar, Jul 10, 2015.
  1. Skylinestar
    Skylinestar
    Dec 24, 2009
    168
    +14
    I have the signal meter. Just like some of the users on amazon/ebay, I can't get the meter to work. I can have the dish pointing at any direction, yet getting a full swing of the needle.
    Is the signal meter specifically designed for C band or Ku band or any band?
  2. TJT1
    TJT1
    Jul 29, 2011
    4,831
    East Sussex, UK
    +1,141
    Is there not a knob on it that you can use to 'turn the signal down' until you get a reading of about half deflection as a starting point and work from there, turning the level up or down as required? All the ones that I have seen have got one.
  3. Skylinestar
    Skylinestar
    Dec 24, 2009
    168
    +14
    There is a knob. I have it in the middle when the dish is not pointing at a sat. When the dish is aimed at a sat, the needle remained at that same place. It doesn't swing up.
  4. TJT1
    TJT1
    Jul 29, 2011
    4,831
    East Sussex, UK
    +1,141
    Broadband. Then either the meter is faulty, or you are not pointing the dish at the sat like you think you are. Do you have a picture and good signal strength on your TV/box when you are 'pointing the dish at the sat'? If so, the meter is probably faulty, but that doesn't seem very likely to me.
  5. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,991
    +1,176
  6. logiciel
    logiciel
    Feb 2, 2008
    53,164
    UK
    +5,789
    How do you know it is?!
  7. Skylinestar
    Skylinestar
    Dec 24, 2009
    168
    +14
    Because I'm getting good reception of the tv channels
  8. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,991
    +1,176
    Then send the faulty meter back...
  9. TJT1
    TJT1
    Jul 29, 2011
    4,831
    East Sussex, UK
    +1,141
    :facepalm:
