Problem with Sagem ITD66
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Cupra, Oct 19, 2005.
  1. Cupra
    Cupra
    I recently bought a Sagem ITD66, mainly because it has a photo card reader. I have it connected to a 5-way scart adapter, which is automatically switched. When the ITD66 is on standby I've noticed that it appears to output some residual signal/interference on the scart. This causes problems when I try to use any other device connected to the scart adapter.
    The ITD66 should not output any signal on the scart when it's on standby. Is this a known fault? I checked the Sagem website and there is no specific mention of this problem. I'm getting the same behaviour when the box is connected directly to the TVs scart port i.e. some residual interference on the screen, so it's not a problem with the scart adapter.
    I need to use an adapter as there's only one RGB enabled scart port on my TV.
    Has anyone else had this problem?
    Thanks.
    Andrew.
