Problem with Radeon
Discussion in 'Desktop & Laptop Computers Forum' started by Steve D Green, Oct 12, 2003.
  1. Steve D Green
    Steve D Green
    I had been running a HCPC with a Radeon 9100, Powerstrip and a Panasonic AE-100.
    Unfortunately my Panasonic died (my fault) and while it was away being repaired, I switched the HCPC to use the s-video to my TV.
    I did notice that the custom Powerstrip resolution panned over a virtual desktop on the TV, however I now have the projector back, and I cannot seem to get it back to the way it was.
    I've uninstalled the ATI drivers, reinstalled powerstrip, but it still pans at the custom res, but if I put it to 800x600 it is OK.
    Any suggestions where I should be looking to get it back the way it was?
    Thanks,
    Steve
  2. Thrash
    Thrash
    Oct 18, 2002
    201
    16
    Adelaide
    Exactly the same problem I had, connect the PC up to a monitor, change it to the custom resolution then connect it back up to the projector. Should work after that.
    See my post - Virtual desktop
  3. Steve D Green
    Steve D Green
    Thanks Thrash, I'll do that tonight.
    Cheers for the quick reply
    - Steve
