Problem with pv500 ??
Discussion in 'Plasma TVs' started by leeboy22001, Jun 2, 2005.
  1. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,020
    48
    +43
    Have had my new 37pv500 for a few days now, and have been very happy with it, but i seem to have a problem with the TV retaining the picture and audio settings!? i can set it up perfectly with all modes set to normal and contrast/brightness/colour/bass/treble etc.. setup to my liking, then i change the av selection to say AV4 watch a bit of dvd, then go back to AV1 and watch my dvr and sometime the picture setting have reset themselves!?? so then have to set them up again! :( has anyone else seen this? :lease: i realise that u can setup each av input to different settings, but can't understand why they reset!? i will try some tests tommorrow to see if a pattern exists when it does it all the time
  2. kevin harrison
    kevin harrison
    Did you work out what was going wrong? I'm having the same problem....Help :lease:
  3. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,029
    2
    4
    137
    Garstang, Lancs
    +1,583
    Is yours 37" aswell?
  4. kevin harrison
    kevin harrison
    Yes. I'm sure it's a simple answer, as Leeboy hasn't posted again so must have had sorted it out,
  5. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,029
    2
    4
    137
    Garstang, Lancs
    +1,583
    Out of interest, you not from the Lancaster area are you?
  6. kevin harrison
    kevin harrison
    No, Nottingham
  7. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,020
    48
    +43
    Hi all, sorry i didn't reply to post, the problem is now sorted, didn't realise that there is a N button next to the multiwindow PIP button that i was pressing :eek: this defaults all settings to default :rolleyes: so good news in the end :clap:
  8. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,029
    2
    4
    137
    Garstang, Lancs
    +1,583
    No prob, the name was familiar, that's all
