Problem with Powerstrip and VGA=>SCART
Discussion in 'Desktop & Laptop Computers Forum' started by Mr.one, Oct 24, 2005.
  1. Mr.one
    Mr.one
    I am having some problems with Powerstrip regarding to a VGA => Scart cable.
    The situation is that I have found a Phillips 28" Widescreen timing that I thinke will do the job on my TV. But the problem is that it only works in bootscreen (until windows is finished with the bootscreen with the blue "timeglas"). Thereafter the TV jumps to blue screen just as if there wasn't any devices connected. The picture in boot isn't perfect, there is some flickering but i gues that it can be fixed with powerstrip later.
    The question is why Windows XP is shutting down the picture after bootscreen?
    I use the following timings:
    PowerStrip timing parameters:
    1024x576=1024,40,48,112,576,5,29,15,19012,312
    Generic timing details for 1024x576:
    HFP=40 HSW=48 HBP=112 kHz=16 VFP=5 VSW=29 VBP=15 Hz=25
    My tv is:
    Phillips 28" 100Hz widescreen tv, so it should be perfect.
    The model is: 28PW9545 Silver.
    It has three scart-connections where two of them is named RGB and the last is CVBS.
    I will just mention that I live in Denmark and therefor use PAL on my tv. (Don't know if that information was any good but now you got it) :)
    Please help me...
    Mr.one
  2. deksawyer
    deksawyer
    May 26, 2005
    1,641
    Fife, Scotland
    +132
    what graphics card do you have..?
    right click and save this doc that I made up a while ago to help people out, if anything's not clear get in touch.
    Also make sure your tv s set to receive the vga rgb signal and not composite etc (I think this is less important though).
    You shouldn't be getting and output from windows during the boot proccess apart from garbled lines; until Powerstrip starts after boot. You shouldn't really have the TV on until windows has fully booted - you could blow it up!
    D.
  3. Mr.one
    Mr.one
  4. stlic
    stlic
    Feb 17, 2004
    769
    +19
    Seeing the boot up screen is normal on some TVs and unreleated to your powerstrip settings which only initiate once you've completely booted into Windows and powerstrip starts up.
    The blue screen is because you are out of sync and so you need to play with you settings.
    My 50Hz settings are below:
    1024x576=1024,41,96,119,576,8,5,44,20250,312
    HFP=41 HSW=96 HBP=119 kHz=16 VFP=8 VSW=5 VBP=44 Hz=25
    Linux modeline parameters:
    "1024x576" 20.250 1024 1065 1161 1280 576 584 589 633 interlace +hsync +vsync
    These work well on my Philips set.
    The good news is that as your colours are nice on boot it seems the cable is working; flickering problem you describe is expected and boot and there's no way around that.
    Perhaps try standard PAL res to see if that works first, the widescreen res doesn't work on all sets.
  5. MikeC
    MikeC
    Mar 14, 2001
    225
    Northants,UK
    +10
    Definitly a sync problem - this is an ideal situation to use vnc (if you have another network attached pc)......
  6. Mr.one
    Mr.one
    Thanks for your replies. I used the timings that deksawyer linked. Thanks alot.
    Since I'm new in Powerstrip I will ask you guys how to make my picture better?
    http://www.eit.ihk-edu.dk/1059/indhold/filupload/upload/Windows-XP.jpg
    There is three mainproblems:
    1) The windows screen is too big (please see the link). It's like approx. 1 inch have been croped out around the whole screen. Can I set a lower resolution (ex. 960x576)?
    2) The picture blur a bit and it also flicker a bit, not much but it's very noticeable in windows explorer as you also can see on the picture.
    3) When I shift to an ordinary channel like TV3 there is a bit of corruption in the picture but I think it will be fixed when problem 1 is fixed.
    Thanks alot so far for your help you will be mentioned in my testament. :)
  7. Mr.one
    Mr.one
    Ups, I forgot to write which timings I use:
    1024x576=1024,32,96,112,576,5,5,39,19750,312
    HFP=32 HSW=96 HBP=112 kHz=16 VFP=5 VSW=5 VBP=39 Hz=25
  8. deksawyer
    deksawyer
    May 26, 2005
    1,641
    Fife, Scotland
    +132
    There's no way to stop the overscan using these timings. A little tip is to move the taskbar so it is two lines or more high and clean up your desktop to remove icons. I have recycle bin and a shortcut to my storage drive. There's also no way to reduce the flicker - it's a balance between excellent TV quality and useable windows quality.
    You could try these timings to redsuce the overscan, but I couldn't get on with them;
    960x540=960,101,56,171,540,21,9,58,20222,33
    Generic timing details for 960x540:
    HFP=101 HSW=56 HBP=171 kHz=16 VFP=21 VSW=9 VBP=58 Hz=25
    "960x540" 20.222 960 1061 1117 1288 540 561 570 628 +hsync +vsync
    This will bring your desktop in from the edges of the screen. Some say it also reduces the flicker, but it didn't for me.
    D.
  9. Mr.one
    Mr.one
    Thanks for the new timings, I got the perfect wide and height on the tv now (it just can't get any better). http://www.eit.ihk-edu.dk/1059/indhold/filupload/upload/Windows-1.jpg
    The picture doesn't flicker as much now but I'm not total satisfied.
    The two final problem is:
    1) The tv doesn't have any good detail level. In the taskbar I can hardly see the time or the taskbar-icons. http://www.eit.ihk-edu.dk/1059/indhold/filupload/upload/Windows-2.jpg
    2) When I turn to another channel like the danish "DR1" the screen start showing something strange (don't know the specific name for it). http://www.eit.ihk-edu.dk/1059/indhold/filupload/upload/Windows-3.jpg
    Got any idea how to solve these problems?
    /Mr.one
  10. deksawyer
    deksawyer
    May 26, 2005
    1,641
    Fife, Scotland
    +132
    the short answer is to buy an LCD or plasma screen.
    the vga-scart solution is meant to enable high quality TV output from our pc to our tv. It's not a solution for everyday web browsing.
    CRT tv's aren't designed for the high resoution output from computers, but it's almost a miracle that we can achieve high quality tv display via vga-scart & powerstrip on a crt tv.
    I'm typing this from my sofa using my tv and it's a pain in the ass (at least I can increase the text size using firefox)!!!!
    In short - don't expect pc monitor quality from your tv.
    Back to my Cab Sov!
    D.
