pROBLEM with PMA-980R Selector knob.
Discussion in 'AV Receivers & Amplifiers' started by umitbat, Jun 9, 2005.
  1. umitbat
    umitbat
    :lease: :lease: Hi
    I bought a PMA-980R online.
    It is ok accept the source selector knob.
    It jumps between sources when i try to change by the knob, it jumps to CD;TUNER;TAPE by clicking 6-8 times before stopping whereever it wants.
    It is OK with the remote it comes to place at once;if i touch the knob it may click by remote too.
    Can this be caused by dust inside the knob?
    Thanks.
  2. Cocs69
    Cocs69
    Aug 24, 2008
    Hi, i know, it's an old problem, but did you resolve that problem with the knob? I have the same problem with the same Denon... Thanks.
