Problem with Pioneer PDP-507XD and SkyHD
Discussion in 'Plasma TVs Forum' started by Oakleyspatz, May 5, 2007.
  1. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,704
    Woking
    +237
    Recently bought this fine Plasma TV and have it connected via HDMI to my Denon AVR-2307 and then HDMI out to my SkyHD box.
    I am finding that every now and again, the image on the tv just goes black for a few seconds and then when it comes back on, the TV is displaying the incoming signal details such as resolution, input and picture mode.
    I have a feeling that it could be the rather cheap HDMI cable I am using from TV to amp ( bought off ebay for a tenner for a 2m length) which is causing a loss in either signal or HDCP handshake. I am hoping the TV is not at fault as I seem to remember a compatibility issue with older generation Pioneer screens and SkyHD.
    Has anyone else had this problem and if so, have you managed to correct it?
    Cheers in advance for any help! :smashin:
    Danny
  2. Rochdale
    Rochdale
    Mar 16, 2002
    359
    Leeds, UK
    I'm running a PDP-507XD and SkyHD over HDMI with no issues here.
  3. Mike999
    Mike999
    Aug 24, 2004
    212
    +13
    I also have Sky HD into the 507XD with no problem, but since the OP is passing the Sky HDMI through the Denon amp I suggest that this is where the problem lies. Try connecting it directly to confirm there's not an issue, in which case the amp/TV interface looks the likely culprit. If so, I'm afraid I don't know of a resolution but at least it would point to the next step. I doubt it's the cheap HDMI cable, but again, using it for a direct connection would eliminate it..
