Problem with Pioneer DVD-108 DL
Discussion in 'Blu-ray & DVD Players & Recorders' started by kane2007uk, Dec 19, 2004.
  1. kane2007uk
    kane2007uk
    I just Bought a pioneer 108 dl
    But when i burn at 4x it takes 30mins instead of 15 mins :-(
    And also if i make a data disc of say 1.6gig it still takes 30mins at 4x
    The firware is 1.14
    Any help with this i would be greatfull
    kane2007uk
  2. laser
    laser
    Aug 1, 2004
    986
    Hartlepool
    +45
    Firmware version is now at 1.18 if you are using the official Pioneer firmware and not the hacked version which provides multi-region support. It maybe worth upgrading to 1.18 if you havn't made the drive multi-region. I'm not sure if a multi-region version of 1.18 exists yet. I'm also using 1.14 (hacked).
    I've also come across this problem and it was due to the type of DVD's I was using. Some cheap DVD's from the computer fair (no brand). I changed over to using Datawrite and Fortis DVD's and had no problems with writing at 4x and 8x.
    What brand of DVD's are you using?
    Are you doing any intensive processing of accessing to a second hard drive while burning DVD's which could cause the 108 to reduce the disc writing speed?
  3. kane2007uk
    kane2007uk
    Thanks for your help
    I use Ritek dvds
    Ive just got firmware 1.18
    ill see if that solves the problem
    Im not doing anything else while burning
    kane2007uk
