Problem with Panny Plasma
Discussion in 'Plasma TVs Forum' started by akleftakis, Oct 19, 2004.
  1. akleftakis
    akleftakis
    I have put up my Plasma screen and got it conected via an one-for-all conector box, and the picture quality is great..however on some of my freeview channels (mostly E4 and Channel 4) part of the picture bends and curves...has anyone else had this problem or has a solution????
    thanks
  2. thedude
    thedude
    Oct 18, 2004
    9,980
    Swindon
    +2,020
    what plasma do you have?
    You may find it does that on all channels check to see it may be smaller on some than most. it cud be either to do with your panel or it cud be because of the box ur using to divide the input
