problem with panny 75e
Discussion in 'Projectors, Screens & Video Processors' started by dancer199, Dec 14, 2004.
  1. dancer199
    dancer199
    hi,
    I have a purple cloud effect in certain areas of my screen, I have cleaned the bulb and the lens but to no avail. can anyone offer any advice as it seems to be getting worse.
    thanks
    d
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Dust blobs would seem the most likely cause .. if you change the focus of the lens do they get clearer, that's a prime indication of dust blobs?
  3. dancer199
    dancer199
    thanks for the reply robin,
    Yes they get softer as you change focus.
    I have opened the unit , cleaned the lens and the bulb but the rest seems to be a sealed unit. any suggestions ?
    thanks
    d
