Problem with Panasonic TX32PM11?
Discussion in 'General TV Discussions Forum' started by azz, Mar 31, 2005.
Tags:
  1. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    Ive just bought the above tv and i am very happy with it but in the mornings or when you first switch it on the screen goes blue for about a second and a half before clearing and then viewing is normal. This TV is the 50hz version.
    Do i need to worry?
    Can i do anything to stop it from happening?
    Is it normal?
    AZz :confused:
  2. billystevo
    billystevo
    Mar 13, 2005
    53
    9
    If you have just bought it your ok for a year if it goes wrong, if you start getting any colour hues ,red green or blue and lines going across the screen thats the sighn of the tube having a short circuit, not being able to control the brightness is another. Keep your eye on it and if the tv does not give you a decent picture get rid before the warrenty runs out. Dont ever think that because you buy a brand like Panasonic your going to be free from faults, all tv manufacturers have outsourced to low wage earning countries , and have had a decline in reliability because of it.
  3. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    Thanks Billystevo,
    That was helpfull. It only happens when its been off for several hours (not in standby).
    I will hang tight for now!
    Thanks again
    Azz
