Problem with Panasonic DMR-HS2
Discussion in 'Blu-ray & DVD Players & Recorders' started by jitasb, Nov 2, 2004.
  1. jitasb
    jitasb
    Nov 2, 2004
    I've got a Pansonic HS2 DVD Recorder, which was all fine until I had a power cut. Now It don't work. When I switch it on, it displays the blue logo disc for a short while then displays "bye" then shuts itself off.
    I have tried unplugging for 2 hours then replugging...no effect.
    P.S. There is a DVD in the drive, but even when I switch to HDD, I still cannot get it to work.
    There must have some sort of safety cut out once the power went off.
    But now how can I reset it , so it boots up properly ?
    Thanks in advance.
  2. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,631
    London
    +476
    switch it on and hold the on/off switch for about 15 seconds.
  3. jitasb
    jitasb
    Nov 2, 2004
    Ekko, thanks for your reply.
    I have tried this..it goes into standby mode okay..but then when i switch it on proper..same thing "bye" then shuts down.
  4. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,631
    London
    +476
    press and hold the standby button for at least 15 seconds. After a while then press it once to switch it on and repeatedly quickly press open. You need to keep doing this in order to get the disc tray to open and get your disc out.
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,855
    Warwick
    +2,773
    The HS2 checks the HDD and the DVD tray before initialising - if either fails then it goes into the cycle your experiencing. As Ekko Star says remove the DVD - if this doesn't solve your problems then it is probable the HDD has failed. Like any HDD if power is pulled during a write operation it is possible for it to be damaged. In which case you'll need a new HDD but will need it installed by Panasonic as it isn't the case of one out, one in I'm afraid...
  6. witters
    witters
    Jul 13, 2000
    12,731
    Yorkshire
    +301
    Not quite true Rasczak.... :)
    I had a noisy HDD in my HS2 and bought another HDD locally and installed it myself. Worked fine. When I switched it on, the HS2 asked if I wanted the new disc formatted. I pressed yes and it was OK from then on.
  7. Rasczak
    Rasczak
    Apr 3, 2002
    21,855
    Warwick
    +2,773
    Interesting - do you have a UK model just out of interest?
  8. witters
    witters
    Jul 13, 2000
    12,731
    Yorkshire
    +301
    Yes I do.
  9. Rasczak
    Rasczak
    Apr 3, 2002
    21,855
    Warwick
    +2,773
    I'm surprised. I have made numerous attempts to 'upgrade' the capacity of my HS2 and always found I needed to mirror the new HDD using a PC before the HS2 would recognise it. Admittedly I had one of the first European HS2 models off the production line so it could have been sourced elsewhere. Anyway good to hear - it will make failed HDDs (a common problem) easy for Panasonic owners...
  10. witters
    witters
    Jul 13, 2000
    12,731
    Yorkshire
    +301
    I should point out that I replaced it with an identical capacity HDD.
  11. jitasb
    jitasb
    Nov 2, 2004
    Thanks for info. Have tried the method of on/off then wait then open/close repeatedly.
    Unfortunately no luck, but I'll give it a try a few more times.
    The power cut occurred while it was in 'DVD' mode rather than HDD, however it was not recording at the time.
    Yep , see the point that it checks if HDD, DVD are okay, but the problem is getting the DVD out of there as the open/close button doesn't do the trick.
  12. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    846
    19
    leeds UK
    +16
    You can't increase the size of the hdd, but you can easily replace it. The machine automatically sees the new drive and formats it for use. It is a standard 40 gig model, and you can install larger drives, you just wont get to use any of the extra space. It is very important that the power consumption is the same or less than the original as there is no spare capacity in the power supply. If you use a faster than 5400rpm drive or a heavier power consumption 5400 model it will probably start faulting whilst burning dvd's.
    Many people have replaced the standard drive with quieter models, if they find the standard noise irritating.
  13. jitasb
    jitasb
    Nov 2, 2004
    Right !! Finally got the DVD out..but the bad news is that the unit still cycles round, then "bye" then switches off.
    So could be a problem with the hard disk drive.
  14. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,631
    London
    +476
    Now try the reset for 15 secs. Failing that leave the thing unplugged overnight and try again tomorrow.
  15. jitasb
    jitasb
    Nov 2, 2004
    Yep..tried that.
    Will try again after leaving it unplugged for a while.
    BUt I suspect that the HDD may have failed.
    How easy is to replace it ? e.g is it similar to repalcing a HDD in a PC ? ..as I have done that a few times without problems.
    P.S Thanks for all the help so far :)
  16. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    846
    19
    leeds UK
    +16
    It is very easy to replace the hard drive, the only difficulty is opening the unit without damaging the front cover as some of the clips are very flimsy. Once open it is a standard hdd unit, however you may have trouble sourcing a 5400rpm 40gig drive these days, and bigger ones have no advantage and may draw too much power from the power supply, faulting the unit when it is trying to burn dvd's.
    Try http://www.thewholewideweb.com/forum/default.asp where you should easily find articles explaining how to do this
  17. arachnidae
    arachnidae
    I have the same problem as described by Jetasb. My HS2 will start powering up, the HD and DVD-RAM reader will start cherning then nothing. The display changes from date and time to time only. The fan stay on and the unit will no longer shut down, even after pressing the power button for 15 s. Anything I try results in the exact same steps as stated (play, open/close, power, dvd, HD etc...) I know it's not a HD problem as I removed the HD and formatted it on my computer and it works fine. I don't know how to check the RAM-Drive since it would not even open anymore.
    When I try to enter the Service Mode (with power OFF, press Pause, Stop and Open/Close simultaneously for 5 s), I get Bye in the display, then back display of time only as above and the unit does not enter service mode.
    Anybody out there who can help please?
  18. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    846
    19
    leeds UK
    +16
    Again visit the site I gave above, there are long discussions about problems of this type. I presume you have a faulty media disc in the drive as if it is empty you will not normally have this problem unless the hdd has failed. If you haven't and the hdd has proved ok the unit itself must have gone wrong. This is very unusual as the hs2 has proved to be a reliable machine on the whole, with most problems relating only to the difficulty of getting over a faulty media in the drive, which stops the machine responding.
  19. Roders
    Roders
    Apr 3, 2009
    Thanks to everyone here.
    I had the same problem with my HS2 after a power outage. System would turn on for a few seconds then say Bye and shutdown.
    Replaced the HDD with another low power consumption 40GB Drive.
    Turned the unit back on, it asked to format the new HDD.
    Then all works again.
    Woohoo :)
    Thanks to all
    Roders
  20. BJAZZZ
    BJAZZZ
    Nov 30, 2005
    5
    Hi Roders, Just moved house went to set up my system and found the machine is going through a similar process (spinning active logo,ask to format disk, is unable to format disk after a while goes into recover the bye). Where did you manage to get your replacment hard drive and how hard to replace.
    If you can let me know that would be excellent only really use it for easy archiving and editing DVDs.
    Thanks in advance for the help.
    Bjazzz
  21. nwgarratt
    nwgarratt
    May 5, 2002
    27,364
    +3,091
    I have a problem with my HS2. It works fine until I put a DVD RAM disc in that it didn't like. It played the titles of the disc fine but then I tried to erase or format the disc, it turned off with the code U11. Now I cannot get the disc out when turning it back on as it goes into recover mode and then switches off.
  22. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    20,960
    +6,808
    Once in the Off position press stop and channel up together [on the unit] for a few seconds to eject the disc.
    Discard the disc because it will likely always cause this problem hereafter.
  23. nwgarratt
    nwgarratt
    May 5, 2002
    27,364
    +3,091
    Thanks but it does nothing. It stays off.
  24. nwgarratt
    nwgarratt
    May 5, 2002
    27,364
    +3,091
    I still cannot get the disc out. When using the eject to switch it on. I get a open just before it powers off but it doesn't actually eject.
    Any other ideas? The machine is ok otherwise.
  25. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    20,960
    +6,808
    Hells teeth. This machine obviously predates this standard over-ride.
    The important point is to get the disc out... then hopefully things will be ok.
    A long press and hold of the eject button might work?
    Even grabbing the tray may be worth it!
  26. nwgarratt
    nwgarratt
    May 5, 2002
    27,364
    +3,091
    Success. The front of the tray actually sticks out a little bit. I pressed eject and jammed a pen knife blade down the side and voila it ejected. :thumbsup::clap:
    Disc is getting scrapped. I may have have more like that as the discs are old (most were bought with the HS2).
  27. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    20,960
    +6,808
    Phew - Good news... and good luck with the machine.
  28. nwgarratt
    nwgarratt
    May 5, 2002
    27,364
    +3,091
    Hopefully, now I know what to do to get a disc out and not waste hours like I just did.
