Problem with one of my boxes
Discussion in 'Satellite TV, Sky TV & FreeSat' started by HMHB, Apr 26, 2016.
  1. HMHB
    HMHB
    Nov 11, 2001
    27,233
    Nottinghamshire
    +6,142
    One of my boxes has developed a problem with series links, recording things from the search by name etc....
    I can only set a program to record if I do it from the Guide. When I do it from a search, it says that the box is still initialising try again later. Even if I leave it switched on for a few hours it still does the same.
    Every time I page forward through the days in the Guide it always has 'searching for listings' initially and then it will load them up.
    Some programs I set to record in the Guide won't offer the series link prompt, yet if I go to the planner after it does allow me to set the series link there.
    I'm sure I tried a full system restore and I know I've done a few planner rebuilds on it, but nothing seems to cure it.
    It's still usable but not as good as it should be, any ideas please?
  2. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,579
    Oxford
    +1,330
    What do you have "Standby mode" set to?
  3. HMHB
    HMHB
    Nov 11, 2001
    27,233
    Nottinghamshire
    +6,142
    Standby mode is set to 'None'
