Problem with NTSC and Sony Wega TV`
Discussion in 'General TV Discussions Forum' started by Messiah, Jan 18, 2003.
  1. Messiah
    Messiah
    Apr 22, 2002
    7,624
    +338
    A friend of mine has a 32" Sony Wega TV and has just bought a Sony all-in-one (DAV-S880 ). First surprise is that the all-in-one does not have any Scart sockets so he is using a Scart to S-Video lead.
    Problem: R2 PAL discs play just fine but R1 NTSC discs are in black and white and give a scrolling effect at the top of the screen. The retailer says his TV is at fault as it cannot accept an NTSC S-Video signal via the Scart socket. Sony tell him this is absolutely untrue and if it was how would they sell these TVs in the US.
    Anyone got any ideas as to why it won't accept an NTSC S-Video signal on the Scart 2 socket?
    Thanks.
  2. John-D
    John-D
    If its like the Tosh, the AV input is default to AV-video in. You have to select the AV input on the TV's menu to s-video, then everything should be OK.
    Hope this works,
    John
  3. Squirrel God
    Squirrel God
    Messiah,
    You need to enable NTSC for S-Video inputs, as it's not enabled by default.
    This is done in the service menu.
    Do a search, it was covered quite recently, as well as a few times n the past. Instructions in a few of those threads.
  4. YellowCows
    YellowCows
    Dec 15, 2002
    141
    Here's a few links to save you the hassle:
    Thread 1
    Thread 2
    Hope that helps
    Moory:)
  5. Messiah
    Messiah
    Apr 22, 2002
    7,624
    +338
    Thanks guys. All sorted :D
