Problem with Newly-bought Samsung HT-AS610 Home Theatre System...
Discussion in 'Home Cinema Buying & Building' started by HprAtvFrk, Dec 28, 2006.
  1. HprAtvFrk
    HprAtvFrk
    Hey guys, I'm new here and posting this thread is probably why I'm here. I'm really confused. I bought the Samsung HT-AS610 sound system for my newly-brought LCD TV, and I can't seem to get all the 5 speakers and one subwoofer working at the same time. I don't know if I'm missing a cable or something.
    Okay, so there are basically 3 modes:
    Stereo - Which is left and right speakers only, along with subwoofer (That works perfectly fine.)
    Dolby Pro Logic II Mode (DPLII) - which has 5 effects: Music, Cinema, Matrix, game, and Prologic. I'm using Matrix because it says, "You will hear 5.1 Channel Surround sound". But when I use it, I hear sound from the 5 speakers, but no sound from the subwoofer.
    SFE Mode (SFE) - Same thing as DPLII, but has 7 effects: Hall, Theatre, Arena, Club, Dome, Stadium, and Church. I'm using Stadium right now because I think it sounds the best. Whenever I turn this mode on, there's sound from the 5 speakers, but no bass from the subwoofer (Same situation as DPLII).
    I really don't know what's wrong. I've connected all the speakers and subwoofer correctly, but I think it's because I plugged in some stuff wrong. I plugged the audio cables from DVD (Audio out) to the receiver (Audio in), but no video out, because I don't have a video out cable for the DVD. Does that affect the problem? and for the Settop Box (Is that the cable box?!?!?!) I also only plugged in the Audio out to the Audio in into the receiver, and no Video out. As for the TV, it says only to plug in the Video In cable into the Video Out cable in the receiver.
    I really don't know what to do, please help me!!! :lease:
    In conclusion: I just want all the 5 speakers and the subwoofer to work together, because there's no point in buying a 5.1 system when you just use the two front speakers and the subwoofer.
    Thanks in advance,:clap:
    -HAF
