problem with new tvseries and monoch 2.5
Discussion in 'Home Entertainment Computers' started by s1ngh, Feb 12, 2009.
  1. s1ngh
    s1ngh
    Apr 23, 2008
    317
    Derby
    +6
    I had streamedmp installed. uninstalled that and got monochrome 2.5 skin now. The tv series is not displaying correctly at the end of each episode there is overlay and also some numbers and icons appearing which i think are if you have viewed an episode or not. How do i get rid of these or can the new tvseries can work with monochrome 2.5
    whats the button for print screen in media portal so can take a screen shot
    cheers
  2. DFENS 360
    DFENS 360
    Jan 7, 2009
    366
    +64
    I'm afraid I can't help you much with your problem but 'F11' is the screenshot key.
  3. s1ngh
    s1ngh
    Apr 23, 2008
    317
    Derby
    +6
    i think because i had streamedmp installed before might have messed it up because it was ok in that skin. deleted cache still the same. gona try reinstalling mediaportal and do things slowllllyyy
  4. davidegee
    davidegee
    Aug 9, 2007
    1,222
    Cambs
    +349
    i had the same problems and ended up having to do a complete fresh install. I only wanted to see how StreamedMP looked and i spent hours getting everything back how it was in the end.
    No help, but just to let you know you are not alone!
  5. s1ngh
    s1ngh
    Apr 23, 2008
    317
    Derby
    +6
    reinstalled it and still the same
    i need to find the old tv series
  6. s1ngh
    s1ngh
    Apr 23, 2008
    317
    Derby
    +6
    these arre the 2 problems attached. might be the xml file needs adjusting?? anybody got working ones on a 1080p screen
  7. Prayin Mantis
    Prayin Mantis
    Aug 17, 2005
    99
    11
    Scotland
    +12
    I doubt its TV series its probably a skin/resolution issue.....have you adjusted the DPI? For monochrome all settings need to be 1366X768...
    Normally with a HTPC on a 1080 screen the icons/text are far too small too read from a distance, so an increase in DPI from the display preference makes it easier to view from a distance....
    The mediaportal skins can't handle this and tend to only operate correctly at a specified resolution.
    I suggest you try the default resolution that the skin has been built for and see if it looks OK - remember and clear the mediaportal cache. If that works then the skin can't handle the adjusted DPI.
  8. s1ngh
    s1ngh
    Apr 23, 2008
    317
    Derby
    +6
    ok i give up lol
    has anyone got the old tvseries files think it was 2.0 as i cant find it anywhere
    thanks
  9. davidegee
    davidegee
    Aug 9, 2007
    1,222
    Cambs
    +349
    you still after version 2 buddy? Think i have it. PM me your email if you want me to get it to you.
  10. s1ngh
    s1ngh
    Apr 23, 2008
    317
    Derby
    +6
    thanks 4 the old tv series but i just realised i need the whole folder for the old tv series because i can only find the new monochrome skin which contains the updated tv series view
