echoUK
Hi guys,
I'm having a few problems trying to set my 360 up so that I can connect to LIVE! and play online. Basically, I upgraded to a wireless router about a month ago and I mainly use my PS3 for gaming, but every now and then I fancy a bash online with the 360. Before I got my wireless I could connect ok (although I had similar problems at first), but after a little fiddle about with a few settings I managed to get connected.
When I first got my wireless router it was in my bedroom and I had actually been able to connect my 360 to it fine by connecting the ethernet into the back of the wireless router itself and setting all the settings to automatic and it connected straight away. Since then though I have moved my wireless connection downstairs because when it was in my room it was actually quite far away from the actual telephone terminal and my Internet speed wasn't as fast as it could be (I was using a really long phone line). Since I've moved it downstairs though my Internet speed has more than doubled, so I don't really want to move it back into my room and slow it down again just for the sake of being able to use the 360 once in a while.
Basically, I'm trying to connect my Xbox using Internet Connection Sharing, which I was doing before I got my wireless connection. I've just spend the last hour or so trying to get my 360 online and it's not having any of it. When I go to 'Test Network' it's passing the first stage fine (actually finding a connection to the computer it's plugged into via ethernet). It's just the next part where it keeps coming up as failed (I think it's the Internet stage where it tries to connect to the internet). When I go onto 'More Info' it says something about not being able to pick up the DNS settings or something and tells me to have a look on the Xbox website. Which I have done and I've tried what it says on there and I still get the same problem.
I've tried everything as automatic and it doesn't work and I've also found out my DNS settings through typing ipconfig/all in the command promp (as what I was told to do on the 360 site). I've then entered the DNS settings manually into my 360 and it's still coming up with the error with the DNS.
Does anybody have any clues as to what I'm doing wrong, as the 360 is connecting to my computer fine, it's just when it tries to make a connection to the net where it keeps coming up as failed and I've tried entering my DNS address but still getting the same.
I'm not really clued up when it comes to IP addresses and network things like that so any help/guidance would be very much appreciated.
Thanks to anybody that can help.
