problem with my sky box
B
Batey
Had sky + since it first came out but recently I had my old box installed in the living room on the extra subscription. It's been working great for the past couple of months but today when I turned it on a message appeared saying "no satellite signal being received". I turned it off at the wall and when I turned it back on I got the same message.
I then checked the signal strenght which wasn't bad but the signal quality box had nothing in it and below that the lock indicator said "not locked". Any ideas ???.
Cheers:( :(
Starburst
Take the standard box and connect it to one of the SKY+ LNB cables, if it works then there is nothing wrong with your digibox and the fault is with the cable or LNB.
