Problem with my new Samsung LCD- green band in centre after standby!?
A
Allister
Hi, Ive had my Samsung LE32R74BD a few days and i've got a strange problem with it. After the tv has been either turned off at the mains or in standby for a while or even playing a dvd when I return to watch TV either through the analogue aerial or my NTL box I get a starange green band going from top to bottow of the screen filling over half the screen and the rest of the screen outside this band is fine! Strangely though if i watch tv via the built in freeview in the tv the picture is always fine, even when analogue and ntl are green!
I've found one way to fix the problem is to turn the tv and ntl box off 5 or six times and suddenly the green band disappears and everything is fine, but then it will return the next morning or whatever!
My ntl is connected via scart and I was wondering whther any1 had had a similiar problem? I dont think there is anything wrong with the tv as it does work fine once the green has gone but having to turn it on and off loads of times before I watch it is a bit annoying!
Any help is much appreciated! :lease:
Allister
b0redj0rd
Allister
I have a similar issue, although I havent noticed it's happening when I'm switching imputs - Occasionally (once every few days) I will see a line of green pixels (horizontal, not vertical) which appear, either on the display when viewing TV or actually in the menu system. A quick change of the channel fixes the problem for me but I've been wondering whether I should take it back sooner rather than later, but as this problem happens rarely I havent yet. If it starts to happen more frequently I'll send it back to Samsung ...
A
Allister
Weird. I'm not sure what to do with mine either as I'm not sure its the tv at fault or my connections- i didnt have this problem with old tv but maybe this one is just more sensitive or whatever.
It's a mystery...........
