Quantcast
Problem with my Amazon TV Fire stick 4k
laserbeam
I did put this thread on another section but was told it would be better to put it on here.
I have a Amazon TV Fire stick 4K which has developed a fault.As I bought it from Amazon they are going to send me a replacement and I will return the faulty one.My question is.Do I just unplug the current fire stick from the TV and then set up the replacement as a new one.Just treat it as being a first time installation.
mitch
Yes just sign in as normal. Might be worth a factory reset on your old one if that’s possible.
