Problem with mouse when restarting my computer
Discussion in 'Computer Peripherals & Consumables' started by ndnchico, Jul 7, 2004.
  1. ndnchico
    ndnchico
    When i restart my computer, my optical mouse turns off and doesnt turn back on. I have to turn the computer off and turn it back on. I have tried other optical mice and i have the same problem. I made this computer but I dont think that has antything to do with it. It is fairly new running an AMD 2400 with MSI-K7N2- delta motherboard. Anyone know what to do????
  2. Bobbler
    Bobbler
    Jun 28, 2004
    346
    +16
    Is it USB or PS2 connection?
    If PS2 is it via adaptor from USB?
    If USB have you tried plugging it in one of the other sockets/swapping another device (not another mouse) to the same socket?
    Is it in a USB hub?
    Do any other USB devices fail to startup properly in other sockets?
    If you can give us some of the above it may help mate.
  3. scooby do
    scooby do
    Dec 11, 2002
    1,762
    48
    +37
    on an NF7 motherboard there is a BIOS fix for this possibly need one for your Msi
  4. ndnchico
    ndnchico
    The mouse is usb. yet I have tried using a ps2 adapter that it came with. I also have a usb keyboard which seems to start up ok when I start the computer. I have tried using different usb ports, yet I have the same problem. My power supply is an antec 430v, so I don't think that that could be the problem as I don't have too much other stuff in there. Like I said, the only other usb device I have connected is my logitech keyboard and that seems to load up properly. I currently have my mouse connected through the ps2 adapter
  5. scooby do
    scooby do
    Dec 11, 2002
    1,762
    48
    +37
    Regardless of PS2 convertor or direct USB my problems were fixed with a BIOS update. I was using a USB mouse with a PS2 adapter and had the same symptoms as you. Simply updated the BIOS and not had a problem since.
  6. ndnchico
    ndnchico
    thanks ill try that
  7. ndnchico
    ndnchico
    i updated my bios today, but i still have the same problem
  8. ndnchico
    ndnchico
    :) i dont know what i did but it works now :)
