Problem with Matrix hi-def
Discussion in 'Xbox Forums' started by Jazz Monkey Jr, Sep 4, 2005.
  1. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Hi everyone,
    I made my xbox hi-def with the splinter cell tweak, and have my games running in 480p. The only hi-def game I have that can go 720p and 1080i is Enter the Matrix. It runs ok when I am PAL but when I use the enigma selector and change to NTSC to get 480p etc it doesn't work. It starts loading and then says the disc is dirty or damaged!!! If you press the info button on the plasma it shows a 1080i input. I have tried just selecting a 720p input but the same happens. Any ideas????
    I have tried selecting the region to PAL, Auto, NTSC Japan and NTSC North America but no joy???
    Does this game only work in PAL mode????
    Any help appreciated, I am not too bothered and the game is crap and I have my 360 on order....but it is a bit annoying.
    Yes, the plasma can accept 720p and 1080i.
    Mal
  2. leedavies
    leedavies
    Jul 8, 2004
    192
    Cambridge
    +7
    I had exactly the same after soft-modding my console. Enter the Matrix just didn't work, exactly as you described. I tried 2 different copies and both behaved the same.
    They went back on eBay pretty quickly.
  3. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    Is it the UK version of Enter the matrix?? If so sounds like it is locked like some Ea games. Get the USA version and it will work fine but of course you need to get round the region coding.
  4. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Thanks Guys,
    I thought that would be the problem,
    never mind, I will just have to wait for my 360 for hi-def heaven...
  5. Dogma21
    Dogma21
    Feb 4, 2005
    381
    Leeds
    +16
    I had the same problem and my xbox is chipped.
    Thought the disc was faulty as it was the first time I had used it.
    At least now I know what the problem was.
  6. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    Hi mal, how ya doing.
    Like some people have said PAL Enter the Matrix will not work in hi-def modes, the codes been removed.
    Some games like the PAL versions of Grand Theft Auto games will not work in NTSC 480p but these simply default to 480i without giving you a black screen.
    There are a few others but not many which have had 480p removed for PAL release, some I've found are Thief:Deadly Shadows, LOTR:THe Third Age and Tiger Woods Golf but other EA Games work OK like Burnout and FIFA.
  7. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Hi Korum,
    I just wanted to see a game in hi-def but I have downloaded some and played them through the VGA, PGR3, Call of duty 2 etc. Just waiting for the 360 now.
  8. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    Have you had a look at Freedom Fighters in high def.It runs in 720p and looks superb, it'll give you a rough idea what the text size etc will look like on your PV500 when the 360 arrives.
