Problem with JVC AV32R25EKS
Discussion in 'General TV Discussions Forum' started by Alan K, Apr 29, 2003.
  1. Alan K
    Alan K
    I just bought a JVC AV32R25EKS! However, the reception from my NTL digital cable suffers from intermittent flickering. I've tried different scart cables and sockets, had NTL come out, and when they checked the connection on a portable, it was fine. I have today had the shop change the TV, but the problem remains! Has anyone any ideas? The DVD, and video connections are fine. When I record from NTL, the flickering doesn't come out on the tape, however, when I watch NTL through the vid's AV channel, the flickering is there.
  2. evans
    evans
    Nov 24, 2002
    1,161
    48
    +36
    well if you got it hooked up via your video its probably that that is causing the interference. Try disconnecting the video and try and single out the problem through trial and error
  3. Alan K
    Alan K
    Thanks for your reply. I have tried that as well as other sorts of combinations, but to no avail. The problem still persists.
