Problem with Ipod 30gb NOT Photo - Reformat
Discussion in 'Headphones, Earphones & Portable Music' started by mytermor, May 7, 2005.
Tags:
  1. mytermor
    mytermor
    I have just purchased an ipod , i plugged it into my pc for the first time and it synced with windows , then the itunes software came up and told me to reformat my ipod using the Ipod Updater so i did that . Now my ipod wont even turn on , not plugged in with the battery charger nor with the battery or plugging it into my computer , it just wont recognize the usb device .
    Anyone know what to do?
  2. HMHB
    HMHB
    Nov 11, 2001
    26,717
    Nottinghamshire
    +5,483
    I assume you used the Restore function of the iPod updater as formatting from windows is a fatal thing to do !
    Does the iPod updater see your iPod ?
    Have you used the latest version of the updater ? If not, download it and try the restore again.
  3. HMHB
    HMHB
    Nov 11, 2001
    26,717
    Nottinghamshire
    +5,483
    You can also try resetting the iPod (I assume it's a 4g one ?) by holding down the Menu and Select buttons together until you see the apple logo - with a bit of luck !
  4. Tejstar
    Tejstar
    Dec 4, 2002
    22,810
    London
    +1,082
    The first time I formatted my iPod it was doing it for 20 mins before I realised something was wrong. I just detached it (using the system tray) and started again and hey presto worked first time!
  5. mytermor
    mytermor
    yes but it now has nothing on the ipod , my pc wont sync with it , it wont turn on ,cant charge or anything! :confused:
  6. HMHB
    HMHB
    Nov 11, 2001
    26,717
    Nottinghamshire
    +5,483
    have you tried a reset by holding those buttons down together for about 10 seconds ?
