gbailey141
Established Member
Hi Guys,
I wonder if you can help with a problem my other half has on her iphone 4. Every so often when she is using it the screen blanks for a couple of seconds and then comes back on again. Also she has had the warning triangle about it over heating. She had a genius appointment yesterday and they told her she had too many apps running in the background and that her battery was now shot to bits. Would you say that this is correct or are they fobbing her off?
Gav
Gav
