Problem with HDMI Connection on Youview Box
I’m experiencing problems with the connection between my Youview Box (Huawei) and my TV (Sony). It’s only started recently and occurs when the TV is switched from 'Standby' to 'On' using the YV Boxes remote which has been programmed to control the TV.
With the boxes’ ‘aerial TV through’ switched off the TV powers up but displays NO SIGNAL. By changing the TV’s input source to the appropriate HDMI port then the output is fine.
I have tried 4 different HDMI cables; also, I have switched between all of the TV inputs (4) all with the same results.
However, if I ‘play about’ with the cable input at the Box it seems to work ok.
Is this a potential problem with the Boxes HDMI connections or is it likely to be something else?
Regards,
Benny.
Regards,
Benny.
