Problem with Harmony 655 Delays
Discussion in 'Home Cinema Control & Remote Controls' started by AgentCool, Jun 1, 2005.
  1. AgentCool
    AgentCool
    Aug 5, 2004
    2,649
    Yorkshire
    +184
    I've had the Logitech Harmony 655 for about a month now but a problem has just emerged that didn't happen before completely out of the blue. When I press the arrow buttons whilst on the TV guide on Sky+, the on-screen marker moves twice instead of once. It's not because I'm holding it down or anything like that. I checked the delay times and tried loads of different combinations with no effect whatsoever. I've been messing around with it for about 2 hours now and I'm at my wits end! Currently the 'inter-key delay' time is set at '0' though I've tried it at 100, 300, 500 and 1000 with no change.
    Any ideas? This is the only thing causing me problems. The control works perfectly with absolutely everything else apart from this!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    ring/email CS mate they will log in and sort it in minutes and as tehy run on central US time i think they may be open now!
  3. scumball
    scumball
    Jan 12, 2004
    6,232
    Harrow - London
    +412
    Have you tried this:
    On your members site go to the Sky box, click Troubleshoot, click Show me more problems, click Satellite doesn't appear to receive every command correctly, click The device responds too much to some commands (for example, volume up increases the volume too quickly) change the number of repeats to 0 - save and update.
    This worked for me on a 659.
  4. AgentCool
    AgentCool
    Aug 5, 2004
    2,649
    Yorkshire
    +184
    Cheers, that repeat thing worked! I have my sanity back at last.
  5. TheCrow
    TheCrow
    Jul 16, 2004
    606
    28
    London
    +47
    I am getting exactly the same thing!
    I will give the "repeat thing" a go.
    These forums are full of good advice :D
    Thanks guys
  6. cabstar
    cabstar
    Mar 28, 2005
    1,026
    38
    Grimsby
    +11
    HMMMM
    Since I last updated mine with new firmware my remote causes every device to jump two steps.
    Gary
  7. TheCrow
    TheCrow
    Jul 16, 2004
    606
    28
    London
    +47
    Scumball's advice fixed my problem :thumbsup: give it a go and see if it works for you.
  8. Big Kev
    Big Kev
    Aug 19, 2003
    291
    +8
    I've just bought a 659 and my Sky+ function is also moving 2 spaces at a time and I've tried setting the repeats to 0 and 1, but to no avail.
    I've even reprogrammed the Satellite function using the RAW method and still no joy.
    Anyone else have an answer?
  9. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,600
    Aberdeenshire
    +182
    I think you've got to call them. There seem to be certain things which cannot be sorted via the site. Twice I have phoned them up after trying for ages to sort a problem and they fix it easily.
  10. Big Kev
    Big Kev
    Aug 19, 2003
    291
    +8
    Cheers kherm, I called them yesterday and they sorted it out whilst I was on the phone, great customer support from Logitech. :)
