Problem with Denon DVD player?
Discussion in 'Blu-ray & DVD Players & Recorders' started by spookster, Mar 25, 2006.
  1. spookster
    spookster
    Jan 15, 2005
    1,412
    Epping
    +154
    I've got a Denon 550 - and I've noticed that when playing DVD's there appears to be colour displacement. Actually, I dont know if thats the right way to describe it.
    Basically, lets say theres a moving image (like a person) it appears that the colour around, lets say the persons face, is waving around a bit too much.
    Its like, at a very subtle level, the colour isnt within its boundaries.
    If anyone can make sense of my rather less than technical describtion, I'd appreciate any help or advice.
    thanks,
  2. 375 driver
    375 driver
    Jan 7, 2006
    68
    +12
  3. spookster
    spookster
    Jan 15, 2005
    1,412
    Epping
    +154
    Do you mean not using scart leads?
  4. 375 driver
    375 driver
    Jan 7, 2006
    68
    +12
    That is correct. If your TV supports this type of connection, try connecting your Denon via the component outputs. These are the Red, Green & Blue phono sockets on the the back of your DVD player. Your user manual should have details on how to set this up.
    Here is a link that might help.
    http://www.tvcables.co.uk/cgi-bin/tvcables/componentvideocable.html
  5. spookster
    spookster
    Jan 15, 2005
    1,412
    Epping
    +154
    The only scart lead I have is the scart from the sky+ box to the back of the tv.
    Strange....
