Problem with Denon 550 - Standby Light Flashing
Discussion in 'AV Receivers & Amplifiers' started by Chem_Eng, Sep 12, 2005.
Tags:
  1. Chem_Eng
    Chem_Eng
    Jan 6, 2005
    Miskin
    Can someone out there help me. I have a problem with the amp on my 550.
    The standby (red led) is flashing on and off. If you press power, it changes to a steady red light. If you press power again, the blue power light flashes on and off, and the display cycles through the inputs, and then the unit switches off, and the standby led starts flashing again. It does this ad infinitum.
    I have tried rebooting the microprocessor, and checked that none of the speaker leads are shorted with no joy. At this point, the manual contains nothing further of any use.
    Any ideas??
  2. Skeets_de
    Skeets_de
    Remove all cables and try again. If it still does it, it's back to Denon. :cool:
