problem with denon 3802
Discussion in 'AV Receivers & Amplifiers' started by pat clancy, Nov 19, 2003.
Tags:
  1. pat clancy
    pat clancy
    Sep 10, 2000
    1,809
    LONDON
    +29
    hi all,last night i connected 6 channel out from tosh 510e to preouts of amp instead of 6 chanell in,now i have no sound from sources connected,dvd ,tv etc,test tone is the only sound i get,i unplugged amp all day ,then tried again,no luck,anyone help,rgrds pat
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    I assume you've already unplugged the 6 channel phono cables from the pre-outs on your 3802?
  3. gwc
    gwc
    Oct 21, 2003
    499
    Wokingham, Berkshire
    +7
    The pre-outs on your amp are for connecting to an external power amp. I don't have a denon but I assume it has a set of external in connections, use these and you should get the tosh sound back;
    Good luck
    gwc
  4. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,463
    United Kingdom
    +1,921
    If you still get nothing then try resetting the amp. Doublecheck the manual but it's usually done by holding down the Stereo and Direct buttons whilst turning the amp power on. Hold for a few seconds and the display will flash and reset everything. Write down all your settings beforehand such as speaker settings, channel levels, delay times, digital assignments etc then you can just key them back in again quickly.
  5. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,751
    71
    Land of the Living, Essex
    +45
    Press auto on source selection on the amp, it should be next to ext in. and analog i beleive.
  6. pat clancy
    pat clancy
    Sep 10, 2000
    1,809
    LONDON
    +29
    cheers crispy its fine now,thanks for all the help guys,i thought i,d blown it,pat
