Problem with deleting songs in Creative Zen Vision:M 60 GB
Discussion in 'Headphones, Earphones & Portable Music' started by bazac, Sep 10, 2007.
  1. bazac
    bazac
    When I try to delete songs from PC Library and My Computer on my Creative Zen Vision:M 60 GB, the files are deleted, but an error message says:
    CTCMSu.exe – Application Error
    The instruction at “0x02b2e6fc” referenced memory at “0x02b98230”. The memory could not be “read”.
    Click on OK to terminate the program
    Click on CANCEL to debug the program
    I tried both OK and CANCEL, and what happens is the program TERMINATES in both cases. No “debugging” whatsoever.
    When I open again the same thing happens.
    This is a very annoying situation, so please help me.
    Thnx
    Daniel
  2. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,608
    Aberdeenshire
    +181
    Did it work OK before, or is this a problem from first use? It may just need a re-install of Mediasource.
  3. bazac
    bazac
    Yep, you were right; I re-installed Creative - add/remove + a THOROUGH cleaning - and everything works beautiful.
    Thnx.
    Daniel
  4. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,608
    Aberdeenshire
    +181
    Glad to hear it :thumbsup:
