Problem with component cable for PS2
Discussion in 'Playstation Forums' started by kenji-san, Mar 7, 2003.
  1. kenji-san
    kenji-san
    I've bought this component cable, a third party one, for my european PS2 and hooked it up to the comp. in on my tv.
    But when I turned it on, it looked like the cable had triggered the macrovision routine; contrast went up and down, and picture kept jumping.
    Okay, maybe because I needed to change from RGB to Y P/b P/r on the PS2 menu?
    Tried it, but without any success.
    why is this? I've read of people who plugged their ps2 to a comp cable without any problem, only had to change the RGB setting for it to work..
    Maybe it's because I got it RGB modded? (so I can see dvd film with RGB scart cable without the green-only problem)
    Any help would be appreciated!
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    I'd say its the because of the mod. I've got 2 ps-2s with component leads that work A-OK and play DVD's through them :)
    Neil.
  3. kenji-san
    kenji-san
    it's definitly the mod. i've just tried the cable with another ps2, and it worked splendid! Although the shifting of the screen 2cm to the left happened as well. I thought this was a scart rgb-only problem?
    Anyway, thanks for the help!
    Kenji-san
