Problem with Canon MD 235 firewire.
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by TYNE-MAG, May 28, 2008.
  1. TYNE-MAG
    TYNE-MAG
    Apr 30, 2008
    39
    11
    I've bought a firewire cable 4 - 6 pin and it's not working. Just doesnt recognise the device.
    I plugged it into the firewire on my computer and it doesnt work. I have rung Canon and they said i should try and update my firewire card, but i'm not sure what mine is! and suspect that it would be a waste of time anyhow.
    Should i bust out and buy a budget firewire card? Anyone got any experience of fixing a problem such as this?
    Thanks for your time.
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    What software are you using to capture/edit? And the capture software doesn't see the camcorder?
    You have the camcorder on in "play" mode, right?
  3. TYNE-MAG
    TYNE-MAG
    Apr 30, 2008
    39
    11
    Yeah i have it on play. I also didnt mention that it already works with the standard three pin connector you get with the 2 video and an audio wire.
    The point of my enquiry is to get the firewire cable working you see. I want to see whether it has a better picture ultimately.
    Plus i notice when i plug in my firewire cable sound comes out of the camera itself, where as when i plugged it in with the other cables there was none. Which suggests to me that firewire doesn't transfer sound. Would that be true?
  4. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Firewire will transfer both the audio and video.
    Again, what software are you using on the PC to capture? You will only be able to transfer video over Firewire using an editing application.
  5. TYNE-MAG
    TYNE-MAG
    Apr 30, 2008
    39
    11
    Sorry i left that out! I have Cyberlink's Director and Producer which came with a plug in video capture device i bought for another camera, and i have Windows Movie Maker. I am using Win XP.
  6. TYNE-MAG
    TYNE-MAG
    Apr 30, 2008
    39
    11
    I think the problem is the firewire port on my pc. Should be fixed soon. thanks.
