Problem with Bemax screen
Discussion in 'Projectors, Screens & Video Processors' started by Phibot, Aug 16, 2004.
  1. Phibot
    Phibot
    Anyone have problems getting the screen to retract.. Its taking me ages to get it to return have to pull it like 100 times to get it to move up and then it catches on next notch on ratchet..
    Could it be faulty ?
    thanks
  2. Sieze
    Sieze
    Aug 17, 2004
    I have the same problem on my screen(not the same manufacturer. I find taking the weight off it and helping it go up faster prevents it from stopping before fully retracting. Its a real knack and was wondering if my is faulty as well?
